Japan racing wheels to s211
Hello!
I'm wondering buy Japan Racing JR21 to my s211
https://www.jmtuonti.fi/vanteet/1216...-silver-m.html
Do you have experience how them will fit?
Most i afraid of the front wheels middle cup (don't know what that is in english :d) don'fit because bearing cup is so big.
I don't want use spacers.
I'm thinkin front 8,5x19 et(offset) 25-30 and rear 9,5 or 10x19 et 30-35
What you think et?
9,5 or 10'' to rear?
What you think et?
Used to put Prodrive GC series on my w124. Allow me to give some info.
1. Bore center is approx. 76 mm or sth like that. You need to reduce the size of bore center to 66.6 mm to fit with Mercedes bore center by using so called Hub Ring (aluminum is better than plastic)
2. PCD is 5/114.3 with cone type nut while Mercedes is PCD 5/112 with ball type nut. You can use wobble nut or make the hole of the wheel a big bigger to fit with PCD Mercedes.
Spacer is for increase or decrease offset of the wheel. If the offset is perfect for it. There is no need to use spacer.
I like 8.5+9.5.
I like 8.5+9.5.
