E-Class (W211) 2003-2009
OBD port ... pin 8
Old Mar 5, 2019 | 07:50 AM
boygould's Avatar
S211 320cdi Sport estate (facelift)
Lightbulb OBD port ... pin 8
Hi, I have a problem with the OBD port on my facelift 2006 320cdi. When plugging in a scanner into the OBD port the unit powers but but does not communicate. Further investigation has found I have no power on pin 8 which should come live when the ignition is on. Please can you advise where the power comes from?
thanks
Chris
Old Mar 5, 2019 | 10:26 AM
tjts1's Avatar
C320
Check your fuses.
Old Mar 5, 2019 | 11:30 AM
boygould's Avatar
Originally Posted by tjts1
Check your fuses.
all fuses that I know about have been checked. Can you be more specific?
ie where does Pin 8 connect to? If it goes via a fuse, which one? What else is supplied from the same circuit. Remember the diagnostic fuse supplies pin 16 which is ok!!
thanks
Old Mar 5, 2019 | 11:31 AM
boygould's Avatar
Checked
Check your fuses.
thanks
