E-Class (W211) 2003-2009
How to check 2003 E500 Battery Control Module
Old Mar 5, 2019 | 12:22 PM
SquareOG's Avatar
E500
Having Power Drain issues, Replaced Battery, checked all fuses, how do I check BCM PN#A2115402745??
Old Mar 5, 2019 | 12:30 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old Mar 6, 2019 | 11:29 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
The car computer would tell you when module is bad. Or at least I would hope so.
Common on this car is that they don't go to sleep. Lately I park my W211 close to the camper where I slept and getting early in the morning, when it was dark, I noticed the Bluetooth light stays on.
Unless you move your phone far away from the car (more than 50') or turn it off, the system will stay on.
That alone will not drain your battery overnight, but observe if your car turns off all the lights and displays within 10 seconds after door close.
Old Mar 7, 2019 | 08:48 PM
Coolharts's Avatar
2003 W211 E320
Check with a tester that can read the BCM. BCMs are discontinued from Mercedes, eBay has them but not all of them work.
Old Mar 8, 2019 | 03:46 PM
kajtek1's Avatar
https://www.mbdirectparts.com/?p=cat...tr=A2115402745
