E-Class (W211) 2003-2009
Hard shift from P to D/R
Old Mar 11, 2019 | 11:55 AM
hemmje's Avatar
mercedes
Exclamation Hard shift from P to D/R
Got the 722.6 - 5 speed auto but I have some hard shift from Park to Reverse or from Park to drive , there is no problem in shifting while driving, I only got that very hard bumpy shift my car does from P to D or R . Some there can tell me what that problem can or are caused by?
Thanks alot
Old Mar 11, 2019 | 02:27 PM
konigstiger's Avatar
'71 Pinto
Have someone pull fault code(s) using MB diagnostics.
Old Mar 11, 2019 | 03:39 PM
hemmje's Avatar
mercedes
I alreasy have pull codes... there is none codes for my transmission
Old Mar 12, 2019 | 01:41 PM
AUTOdidact's Avatar
E500 4matic
First you should always check the fluid level, maybe it´s a bit too low. Therefor you need a special dipstick (+ fill cap and lock pin to reclose the fill tube) available at eBay, Amazon etc.
Old Mar 12, 2019 | 09:29 PM
F1Fan's Avatar
Replace the transmission mount. It is super easy to do and will help with the shifts from P to D or R.
Old Mar 13, 2019 | 02:33 PM
AUTOdidact's Avatar
E500 4matic
... if it´s worn out. You can visually check the rubber insert and try to move the driveshaft where it´s connected to the transmission.
Also check the rubber flex discs on both ends of the driveshaft.
