E-Class (W211) 2003-2009
W211 E220 CDi unknown object
Old Mar 18, 2019 | 03:45 AM
Fakhri's Avatar
Mercedes Benz E220 CDI, 2002, Classic
Question W211 E220 CDi unknown object
Hi friends, I found this on my car, it is in front passenger side, under the glove compartment. Does anybody know what is it for? There is rope on the head, you can pull it, then it goes back. Didn't see any connection to anything
Old Mar 18, 2019 | 04:33 PM
DarthBudice's Avatar
08 E350 4MATIC
Does your glove box just flop open now?
Old Mar 18, 2019 | 06:01 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
What DB said. It's the dampener for the glove box door.
Old Mar 18, 2019 | 06:23 PM
jimbo1763's Avatar
2007 E350 Sedan
+2. It's the "shock absorber" for the glove box door that allows it to open slowly.
If your glove box door just flops open, it means that the little line that is attached to the absorber has come loose from its mooring. That is usually fixed with a zip tie or something like that-a small plastic piece that it is meant to attach to it breaks, and the damping effect of the absorber is lost until you reconnect it.
There are a few threads here about that. Common issue.
Old Mar 30, 2019 | 01:40 AM
Fakhri's Avatar
Thank you for replying
Old Mar 30, 2019 | 01:42 AM
Fakhri's Avatar
Thank you for your replies,
Yes glove box flops when I open it, I will try to fix it
Old Mar 30, 2019 | 10:59 AM
konigstiger's Avatar
'71 Pinto
FYI part # 2116800026
