E-Class (W211) 2003-2009
Belt tension
Old Apr 8, 2019 | 02:16 PM
Kmaddentx's Avatar
2005 E500 base (W211)
Belt tension
Does anyone know how to add tension to an e500 base (W211)? I installed a new tensioner pulley assembly and bought a new belt, but the belt is very loose. I can take it off by hand. The tensioner doesn't seem adjustable, and I don't think the alternator is mounted on an adjustable bracket, so I'm at a loss.
Old Apr 8, 2019 | 03:08 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Two possibilities:
-You received an incorrect belt. Or,
-you did not remove the lock pin from the tensioner; tensioners are shipped in the "open" position with a lock pin in them that you must remove. Just put a bit of torque on the bolt head, slip the pin out, then release the tensioner onto the belt.
Photo from partsgeek.
Old Apr 8, 2019 | 03:39 PM
Kmaddentx's Avatar
Thanks! I'm sure it's the pin. I had no instructions, but should have figured that ou
  1. Originally Posted by bbirdwell
    Two possibilities:
Old Apr 10, 2019 | 12:57 PM
Milkyrice's Avatar
w211 e500
He 100% forgot to remove the locking pin.
