E-Class (W211) 2003-2009
07 E Class Keyless Entry Troubles
Old Apr 21, 2019 | 11:21 AM
Red Rasta's Avatar
07 e350
Hello Ya'll, I have had an 07 E 350 for a few years. At first all 3 entry door lock/unlock feature worked fine. Only driver front was bad. There was no definitive click inside of handle so I figured it was for sure handle. I replaced with a used one off ebay and it didn't work even though I felt click. Looked like wiring had a short so I ordered a second used. This time it worked perfect for a few months, and then went to lock button working only. After a couple months lock button stopped too. So I am back to using rear handle to open but now it is working intermittently. It beeps everytime when pulled, but doesn't unlock often and lock button does not work either. Strange thing is, if I pull front and rear at the same time, sometimes it will unlock. Both passenger side have not had any issues so I am not sure if it is an antennae problem or not. Key Fob has no problems. Also I noticed the Key Fob has to be practically touching the handle sensor to use the roll up all windows feature when locking. It used to work at a distance. I love this car, but it sure would be nice to correct all the problems like cleaning of the steering wheel sensor, replacing the camshaft magnets, and repairing the back window shade that is always up.
Old Apr 21, 2019 | 12:49 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old Apr 21, 2019 | 11:09 PM
cetialpha5's Avatar
I would never get a used handle, it will just eventually fail like the original ones did. They only seem to be good for a few years. You could just buy one of the handles online. Could be in the $200 range instead of the $300+ at the dealer. I would also replace the battery in the keyfob and keep your phone away from the key fob as that sometimes blocks the signal.
Old Apr 22, 2019 | 05:42 AM
pppcguy's Avatar
w211e200komestate
You may have to check the antenna module at the rear door https://www.ebay.com/itm/Mercedes-W2...cAAOSwEeFU-c2L as I remembered that someone had fixed this problem by replacing this item.
Old Apr 22, 2019 | 08:28 AM
NorsemanE320's Avatar
MB E320CDI
Hi! Do you have a adress to a online store seiling these handles? 3 of 4 is broken on my 2004 E-class, and the dealer in Norway charge over $400 each. Since MB made it more difficult with paralell import, it's hard to find a decent alternative.
Old Apr 22, 2019 | 10:08 AM
konigstiger's Avatar
'71 Pinto
Search: front left 21176011709723, right 21176012709723; rear 21176013709723, 21176014709723.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 27, 2023 | 03:06 AM
Norskpatriot's Avatar
R320 Bluetec
Thumbs up
www.aliexpress.com, koster ca. 500 kr pr stk, ihvertfall for r-class, så må du slette alle feilkodene ;-)
