New to the MB World
I just purchased my first MBZ 2009 E350 or W211
I lucked out and found a friend that gave me the quick lesson about the MBWorld forum and there is a ton of great data here.
I want to start by doing the standard tune up stuff and skip most of the hard lesson curve if possible.
Go straight to Best parts tried and true.
Engine oil
Tran’s oil
Filters
Service times, oil is 12K and what about the Trans?
This car has 67,500 Miles and seems to be in great condition minus service records, questions like Trans filter and fluid? Trans flush. Do the right thing without killing the Trans by causing any problems.
Same with Oil, Mobil one 0/40 or? Also I am having trouble locating the fill chart, how much oil goes in with filter change?
Thank You All in advance
All suggestions welcome
My first MBZ
2009 E350 or W 211
I think you have 1st generation of 7G transmission, who calls for only service at 40k miles. Try to get Master Inquiry to see what was done on the car.
Register on mbusa.com and that will give you manuals if you are missing them.
Fantastic.
The FSS ? Please translate.
the dash service says 3 days left.
and How can I go about getting a Master Inquiry ?
MBUSA.com will provide the OE User Manuals or are you talking factory Manuals ?
Thank You for your time and reply.
As for the oil, Mobil 1 0w40 is fine, there's actually a $12 rebate on 5 quart jugs with a limit of 4. I believe your car takes 8.5 quarts of oil. Walmart has the 5 quart jug for $22.88. And although Walmart isn't on the list, they always honor the rebate from them.
https://slickdeals.net/f/12986812-mobil-1-motor-oil-and-filter-rebates-up-to-17-off
I have to say this car is growing on me quick.
I believe the front push pin supports or possibly structural supports might have been compromised.
I will need a lift to give it a good eye grind.
unless somebody has seen this ?
As for your front end, I have no idea what you even mean by catches on parking stops. Front end noises need to be diagnosed on a lift.
it seems to be sagging a bit as if there are broken push pins.
I need to get it on a lift, but I have seen other cars that have broken body panel cover & supports that have caused the same problem.
thanks for the information, I will check with dealer when i pick the parts i ordered.
Couldn't find a 2009 when I was looking.
What's the color called?
Should provide a good decade of service with regular maintenance.
Find an indy or pay the dealership - your time is valuable too.
Engine will break in just after 100k (my 08 hit 105k a month ago).
MI is something dealers can give you, but they hesitate if you don't service car with them and will give you privacy BS.
We did have forum members who could pull it, so ask around.
Did you check mbusa site? They provide user and service manuals for free, but if you need WIS, than you'd have to pay for subscription, or talk to konighstiger.
Good luck with the car.
