Flexible Service System details
Received 4,435 Likes
'71 Pinto
As a matter of reference this is what you're entitled to for:
Flexible Service System - A-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Flexible Service System - B-Service
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
'71 Pinto
Man, I should have never had that third espresso.
2004 E 4matic StationWagon
Service C or D
You wouldn't happen to have a list of the services performed for C and D by any chance, would you? Also, I am curious how the FSS decides which service is appropriate. I have an E500 wagon with 7575 miles, and the computer says that the C service is called for in approximately 4,000 miles, even though I have not had the A or B service. (I did change the oil at 5,000 miles, though, if that is relevant.)
'71 Pinto
Unfortunately I don’t have details for C & D services. I would suggest contacting mbtech208 who moderates the tech forum - https://mbworld.org/forums/search.php?searchid=17503
FSS evaluates engine temperature, oil level, vehicle speed, engine speed, and distance driven created by your individual driving style.
Can an owner change the oil sooner than calculated by the FSS? Absolutely, the FSS be reset if more frequent oil changes are done - the instructions are in the Owner's Manual.
'71 Pinto
Now where did I put that...?
'71 Pinto
Instructions are listed on pg 279 the (2003) Operator's Manual. Calling up the service item menu:
Switch ignition on
Go to std display (outside temperature)
Choose FSS PLUS
Press reset knob (used for resetting the odometer)for 5 seconds
SERVICE MENU appears
Select ITEMS
Press menu button
The service items to be carried out are shown
Numbered items are detailed in the Serevice Booklet
Switch ignition on
Choose FSS PLUS
Select ITEMS
Press menu button
2004 E320, 2004 Lexus GX470
When you got your oil changed at 5000, how did that work with your free scheduled maintenance (fsm) since you performed this early?
I have the fsm, however, I just want to get my oil changed before 10,000. I presume I'll pay for the early oil change, but I want to make sure the other 10,000mi checks will be done at same point had I not completed the early oil change.
2015 ML 350
I just got a advertising flyer from the MB dealer in the neighborhood for a Lube Oil & Filter on a V8 E class which included a few "check this, look at that" BS items "included"... $169.95 USD
$169 seems high an oil change. Even by MB, so there must a lot other checks. Precision MB & Porsche in W. Atlantic City is advertising a free brake check, fwiw.
