Rear interior lamp not working
Well the reading lamps in the rear lamp is working perfect but i cant get the interior light in passenger rear working, the light in the trunk is working perfect.
I have checked the bulb and i have try replacing the lamp, but still the rear cabin light will not work.. '
There is a flat 4 pin cable from the front interior lamp to the rar, any there can tell me which pin to test ?
And the motion sensor for the cabin is not working either.
i got these fault code
9022 Component e15/3 (rear interior lamp) has short or open circuit OR component e15/3 dome lamp has short circuit or open circuit.
90A0 communication error in serial communication interface to rear lamps and interior motion sensor: no communication echo on serial line.
90A5 the interior protection reports a fault in the glass breakage loop.
Hope some expert can give me some information to repair that annoying problem..
but did OP find a solution to this problem?
I myself also have non working rear interior lights and non operative mood lightning at the back.
The reading lamps are working fine all the time.
Yesterday the lights started working again only to find out this morning they broke again -_-
The car also had the interior motion sensor and when the lights fail, the motion sensor also won't go up when unlocking the car.
All the rest of the interior lights work perfect! even the rain sensor etc is working as it should (or so I think anyway)
I was just near my rear passenger ceiling LT and I have to revisit my OCP for a bad toggle LT switch.
