E-Class (W211) 2003-2009
how to remove cupholder?
Old Jul 14, 2004 | 01:24 PM
usafvet's Avatar
2003 e320
how do you remove the inside (elevated) cupholder that pops out? thanks
Old Jul 14, 2004 | 01:41 PM
bmms8's Avatar
MB
basically you just have to pull it open. you might have to use some force. putting it back is harder imo. GL
Old Jul 14, 2004 | 03:06 PM
Barry45RPM's Avatar
2015 ML 350
Removal
The cupholder assembly comes out as a unit. (Upper & lower & supporting framework/mechanism w/ both cup holders)
1. Open door
2. open cup holders to upright position.
3. look into the pot, on the rearward side, there is an oval indented moulded part to receive your fingertips.
4. put 2 fingers into the dent firmly & pull straight up.
It is a "snap fit" item but a quick jerk will do it.
The manual says to remove the cup holder to clean them every so often but makes no mention on how to do it. I finally said to hell with it & did it.
Old Jul 14, 2004 | 04:04 PM
BklynBenz's Avatar
CL500
i broke mine taking it out in my clk, pulled too hard i guess. i just left it out and i actually like it better that way.
Old Jul 14, 2004 | 04:28 PM
deuce zer0's Avatar
E63
mine borke too. but its just the part that swings out. I actually want to get another but just havent been motivated to do so. I plan on just calling around to junk yards and seeing if they have any w210's in. I am sure it wouldnt be gone if they have one.
Old Jul 14, 2004 | 04:43 PM
Barry45RPM's Avatar
2015 ML 350
Don't pull it out by any of the mechanical parts !!!!!!!!!!!!!!!!!! Stick your fingers down the hole (drivers cup hole) & pull it straight up by the back of the box.
Its a tight snap fit, but once it comes out you will see where the "tabs" interlock with the inner walls of the compartment.
Old Jul 14, 2004 | 04:48 PM
BklynBenz's Avatar
CL500
it wasnt the first time i broke mine. my dealer actually replaced mine for free the first time and i think they list for like over $100.
Old Oct 20, 2024 | 04:45 AM
Hughpaulk's Avatar
How to remove and replace the popout cup holders on a 2003 SL55 AMG
Spoiler
Old Oct 22, 2024 | 07:18 PM
Hughpaulk's Avatar
Cup holder
How do you remove and install pop out cup holders ona 2003 SL55 AMG
