Steering suspension
I had my tires changed at Costco and the guy said the passenger tire was wearing uneven, that being said I drove it home and jacked the front up and the driver side is tight but the passenger side 3&9 position is tight but the 12&6 position has some play. Does anybody know what that could be or is it common and I drove it this morning and it does have a slight pull to the right. I know it is a loaded question just checking my options before getting alignment
12&6 could be the upper and/or lower ball joint. Not sure what year your car is, but if your upper ball joint is held to the upper wishbone with 3 bolts, then the ball joint can be easily removed and replaced. I'm talking about something like part #A0003301007. Lower ball joint, you would need a ball joint clamp to remove it off the knuckle. So the upper is DIY doable, the part is roughly $30~40. The lower, if you have the special tool and experience in doing it, then go ahead. But if not, this would be for a mechanic, preferably someone who has worked on Mercedes before.
If it was the wheel bearing, I assume there would be play in every position. The spring control arm also has a ball joint at the end that attaches to the knuckle. That ball joint may be bad and is letting the wheel move.
