Secondary air injection DELETE?
Can this be done on a 2007 E350 m272?
I have done this on my e55 but the menus are different on this model and I cant find the bit to deactivate the air pump?
Im not even sure if its possible?
The following 2 users liked this post by MBENZTECH:
austingtir (11-12-2019),
Minh (01-06-2021)
Thank you but where exactly is that?
I went through multiple menus to try find it.
The layout is totally different to the E55 amgs.
On the e55 it is:
control units
drive
mesfi 2.8
development data
control unit adaptations
control unit adaptations (variant coding)
implizite kodierung me281 amg c6-stand
scroll to 0178 and change diagnose ein to diagnose aus...
99 model w210 e55 amg
On the e55 it is:
control units
drive
mesfi 2.8
development data
On the e55 it is:
control units
drive
mesfi 2.8
development data
hello is it the same with the w210 and w28 M113 engine? Thank you very much
Not having to pay big $$$ for a secondary air injection blower replacement....
I could not get this to work on this E350 its not the same menu wise as an e55 amg.
What I ended up doing was I found the old blow motor was melted/seized in the housing. I just happened to have a crashed E63 amg with a damaged secondary air injection blower housing so I swapped the motor and fan unit into the different housing E350 unit.
I have no solution for coding out secondary air injection on an E350.
Ok I figured it out
car must be running Follow same rules for 2.8 only thing is look for “SLP”. Turn off. Save n that’s it. I passed NY emission and monitor showed as ready. I figured it out by trial n error lol. Hopes this helps someone. Got tired of trying to fix p0410 n not able to pass inspection in Ny. Plus u can’t buy the sticker anymore since they changed it to barcode now hopes this helps someone like when I needed it n couldn’t find it nowhere
