e500 5spd trans wont engage
By this time everyone was laying on their horn. I quickly shifted to park then back to drive. Still nothing. Same for reverse. I was able to get the assistance of a nice women and we pushed the car off the road. Cycling the ignition did not correct the issue. i looked under the car for any fluid leaks or visible signs of damage..... nothing.
After the car sat for 10 minutes i tried to move the car. there was engagement but before attempting to get back on the road i stopped, selected reverse, and didnt get the warm and fuzzy that everything was back to normal. it felt like it was slipping in reverse. selecting drive again, nothing. just revs.
So i called for a tow to get it to the nearest shop.
Shop calls after looking the car over and says it needs a trans. i asked if there were any codes and they said they had not checked yet. How did they come to the conclusion that the trans had failed without and diagnosis? they said they drove it after it sat all night and when cold the trans worked great but after warming up the trans stopped.
I asked the shop to check for codes and do an inspection, that the trans is know for commutator plate issues and the pass through of the harness. told them the car was at temp all day and had no hesitation or abnormal shifts. the only thing that happened that day that could have impacted the performance of the trans was that i had gone to an automatic car wash. possibly water had gotten into the harness. who knows.
so my question is, has anyone had a similar transmission issue and found the solution?
searching the threads the only similar issue was the shift linkage coming loose. but seeing as i was already under way .... and the shop was able to move the vehicle, we can rule that out.
the shop wants over 3k for a used trans plus any other stuff that will need to be replaced like exhaust clamps and what not. ive fallen on hard times due to ongoing health issues and cannot shoulder that kind of expense especially after no proper diagnosis.
