Hi! My first post. Need help with brake lights warning message w211
I just bought this car yesterday and I have a few messages stating that I have brake lights out and that back up ones are on. I pulled the light clusters out and indeed the top brake lights are out on both sides. The funny thing is I ran 12v directly to the top bulbs and they both turned on. 2004 E320??
Please help Thank you!!
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,930 Likes
2017 GLE350 4MATIC
Welcome! Please post a photo of the E.
You can not buy just one bulb! I've read every post twice on here that has anything close to pertaining to my situation. The only thing I can try is buying the right side cluster and see if that works. I guess they run in series, so if the right goes out they both go out.
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
check the globe holders contact points on the fixed board connected to the tail light
common to have burnt contacts, if so and your handy with a soldering iron and wires you could mend it yourself. otherwise buy new board/ tail light
Also worth checking if the wiring plug leading to the board is burnt out.
don't quote me but from memory i do believe if one brake light is blown/faulty then both sides will run backups.
