E-Class (W211) 2003-2009
HELP!! Fuel gauge issue.
Old Nov 20, 2019 | 06:27 PM
Johnny L Ortega's Avatar
2004 Mercedes-Benz E320 4matic w211
The fuel gauge comes on and works when it wants. I just replaced the sending unit with a brand new one on the left side of the tank and still no luck. I have so many DTC codes its Mind boggling! I've read every post that even slightly pertains to my issue.
Please help me get my gas guage working we are supposed to visit family out of town for Thanksgiving, but I will not go with the gas guage not working properly. It would be way to risky with our 2 year old. TY
Old Nov 20, 2019 | 07:58 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Risky? Do you have a rough guess of how far you can go on a tank of fuel? A gas gauge is convenient, nothing more.
Fill the fuel tank, reset one of the trip meters to zero, drive happy. If you want to go crazy with it, fill up your tank again after 200 miles and reset the meter again. 200 miles is about as far as you can sanely go with a two year old anyway...
Old Nov 20, 2019 | 08:21 PM
Bump!
Old Nov 20, 2019 | 09:09 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Sounds like the float is hung up on the internal fuel lines in the tank. You're gonna to have to open it up again. Until then, use the trip odometer figuring 20 mpg; max 420 miles per tank. Refuel every 300 miles and reset odometer each time you refuel. When "low fuel light" comes on you have four gallons of fuel remaining in the tank.
Old Nov 20, 2019 | 09:19 PM
Thank you for your reply. I will open it back up and try and to free it up. Do you know what side sensor 2 is on? My wife said it's a no go for her if I dont get the fuel guage working. We live in western NY and we deal with fridgid temps. She does not want to temp it.
Happy wife Happy life!!
Old Nov 20, 2019 | 09:21 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Sounds like you might just miss 15 years warranty?
If I understand the sides, the code is for jammed sensor on passenger side, so putting new unit on driver side is not going to fix it.
Still as members above suggest, driving by odometer is not a big deal, while getting 2.5 gallons can for emergency is also easy.
Old Nov 20, 2019 | 09:28 PM
I've been researching about this issue for the past 5 days non stop and barely today I stumbled upon that warranty. My driver side sending unit had a puddle when the tank was full.🤦‍♂️🤦‍♂️ dollar short day late
I bought the car last week and love it. It is a mint condition one owner old lady driven w211. Except the fuel guage
Old Nov 20, 2019 | 10:30 PM
A FEW OTHER CODES THAT MAY OR MAY NOT BE RELATED
Old Nov 20, 2019 | 10:45 PM
I tired uploading pictures of 59 DTC error messages, but you are only aloud 40
Old Nov 21, 2019 | 12:02 AM
kajtek1's Avatar
Sounds like you might have accumulation of codes from life of the car.
Worry only about active or pending, while ignore stored. Best way is to clear them all and recheck after some driving.
Now on fuel tank, beware that saddle tank uses Venturi pump to transfer fuel from passenger butt to driver butt, where electric pump gets it to the engine.
When Venturi is misaligned and lot of people not familiar with it do that - you will not be able to use about 6 gallons of fuel that sits in passenger butt.
So before you sort it all out, better carry extra fuel in can.
Old Nov 21, 2019 | 07:38 AM
I will re align the sending unit
Old Nov 21, 2019 | 09:24 AM
I did align the two units back to where they were. I did use a paint marker pre removal to mark the exact position of each unit. 🤔🤔
I hate to sell it, but this has me stumped and my wife refuse to use it when we get below 0° weather here in western NY. Cant afford the stealership!!
I can try and buy the other side. I'm just wondering what side sensor 2 is? Going to pull another $300 out the bank for the passenger side fuel level sensor. Even tho the pump works perfectly
Old Nov 21, 2019 | 10:26 AM
I went ahead and double checked if I aligned the sending unit back to where it was prior to and sure enough it was off a little. The guage is working correctly!! 😊😊 I turned it a little more towards the passenger side. I will monitor it for a few days of driving just to see if it is going back to being just sporadically working and report back in a few days!!
THANK YOU ALL SO VERY MUCH! AND HAPPY HOLIDAYS
Old Nov 21, 2019 | 01:23 PM
Not working again! I came out on my break to check it.
Old Nov 21, 2019 | 01:51 PM
kajtek1's Avatar
Did you ever pull passenger side sender?
The tank has 2 level sensors due to "saddle" design and that works with computer program, that gives you estimated fuel level.
Old Nov 21, 2019 | 01:59 PM
Yes! I had to in order to replace driver side unit.
Now it's working 🤦‍♂️
Old Nov 21, 2019 | 02:00 PM
Now I have a code P0446, but think that is do to me loosening the driver side unit to adjust it.
Old Nov 21, 2019 | 07:55 PM
2013 ML350 Bluetec
That could be as simple as a loose gas cap. Or what you said.
Old Nov 21, 2019 | 08:41 PM
First thing I checked was the gas cap! I rest the ECU let's see what happens in the following day.
Old Nov 21, 2019 | 08:42 PM
Gas guage has been working all day so far
FINGERS CROSSED!!
Old Nov 21, 2019 | 08:43 PM
I must say I love the feel of this car gas guage or not smooth as butter
Old Nov 21, 2019 | 08:44 PM
For being almost 20 years old
Old Nov 22, 2019 | 01:11 PM
NOT WORKING 😡😡
Old Nov 22, 2019 | 05:53 PM
Well I ponyed up the money for the passenger fuel level sensor/pump. Let's see if my fuel guage will work. Should be here in about a week!!
Old Jan 24, 2020 | 07:55 AM
Ivan-2019's Avatar
2004 E500 4matic
Curious if you ever got this gremlin sorted out of your fuel gauge...?
