E-Class (W211) 2003-2009
Loss of power
Old Nov 26, 2019 | 04:36 AM
Bassam Hammoud's Avatar
w211
Question Loss of power
Hello, i have a w211 e350 2007, i had replaced the torque due to malfunction but now i have another problem is when im on the highway i suddenly lose power and if i accelerate the engine starts screaming but no power, then i put my gear on N then on D and everything is back to normal again, if im heading to the mountain and im going hard sometimes suddenly my rpm goes from 4k to 1k in 2 seconds and back to 4k again with power loss also. whats the problem ?
Old Nov 26, 2019 | 05:28 AM
Spinning's Avatar
E90 320i, D23 Navara, EL XR8, 207 E200
Any warning lights?
Also what did u replace in terms of the torque?
Can u get the vehicle scanned via obd and post results
Old Nov 26, 2019 | 05:30 AM
w211
just check engine nothing more, i replaced the torque itself. will get OBD soon and post the results
Old Nov 26, 2019 | 05:51 AM
Spinning's Avatar
the torque converter?
​​​​​​​had an auto trans service? the first example you provided sounds like it could be low on trans fluid, but dont take my word until we see those codes
Old Nov 26, 2019 | 06:03 AM
w211
Yes the torque converter, trans service is done after the torque replacement and fluids are on point. what options are we looking into ?
Old Nov 26, 2019 | 06:21 AM
Spinning's Avatar
without the codes id be looking into either the shift solenoids, transmission conductor plate or fluid level of trans.
Old Nov 26, 2019 | 02:02 PM
cetialpha5's Avatar
Don't forget about replacing the transmission connector, it's a cheap part, but once it starts wicking up transmission fluid, strange things start to happen.
Old Nov 27, 2019 | 01:59 AM
w211
Whats with the transmission connector ? i didnt change it.
Old Nov 27, 2019 | 02:07 AM
cetialpha5's Avatar
Is the car a 4matic?
https://www.fcpeuro.com/products/mer...tor-2035400053
Old Nov 27, 2019 | 02:16 AM
Spinning's Avatar
Yes thats another thing worth replacing, it connects the transmission wiring loom to the conductor plate, from memory the bolt is a 6mm?
Old Nov 27, 2019 | 02:50 AM
w211
No 2 wheel drive. and i will replace the connector this weekend if its cheap its worth trying then
Old Nov 27, 2019 | 02:55 AM
cetialpha5's Avatar
Well I don't think the 7 speed had it. So either fluid level or conductor plate, as others said, get a scanner and get the codes.
https://www.amazon.com/Autel-Diaglink-Version-Diagnostic-Transmission/dp/B01N0QQZY7 https://www.amazon.com/Autel-Diaglink-Version-Diagnostic-Transmission/dp/B01N0QQZY7
Old Nov 28, 2019 | 01:51 PM
w211
8 engine faults : thats the engine faults i have detected today.
engine faults also
3 trany faults
What do you think guys ?
Old Nov 28, 2019 | 03:37 PM
Bankroll's Avatar
E55 AMG
That's an easy one. Whoever worked on it last, screwed up. Take it back to the repair shop that did the transmission work.
Old Nov 28, 2019 | 04:07 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
Clear ALL codes (your trans. codes are stored, but not active), triple check the fluid level (I think it'll be low), test drive, see what codes return. There appears to be maintenance required on a few areas of this car,
Old Nov 28, 2019 | 09:47 PM
cetialpha5's Avatar
Yeah, it might actually be ok once the codes are cleared. You have other issues with the car. Search for intake manifold, sounds like it's also time for a new intake manifold. Camshaft sensors might also need to be replaced, but those error codes are stored not present so maybe it'll be ok once everything is cleared. Once cleared, scan again after driving for a bit to see if codes come back.
Old Nov 29, 2019 | 04:34 AM
Spinning's Avatar
did the workshop who replaced the torque converter scan and clear the codes once they were satisfied with the work? if not as suggested above i'd be clearing and test driving than have a re-scan on the codes to see what returns.
may be worth adapting the transmission yourself while your at it
have a look at the tumble flap shafts to see if they've broken away from their linkage's
