E-Class (W211) 2003-2009
How to test MAP/MAF sensor
Old Dec 4, 2019 | 07:52 PM
arcteryx's Avatar
W211 CDI
The WIS I have is not showing how to test the MAP and MAF sensors. This is a pretty critical piece of data to work on vehicles. Does someone know how to do this and/or what the resistance should be between the pins? I searched for Bosch too and came up empty.
Old Dec 4, 2019 | 08:10 PM
tjts1's Avatar
C320
Use a scan tool like icarsoft or Foxwell to see maf and map live data.
Old Dec 4, 2019 | 08:23 PM
arcteryx's Avatar
W211 CDI
Yes I can do that, I have a Foxwell. But what are the ranges though? I can't seem to find what acceptable values are.
Old Dec 4, 2019 | 08:30 PM
tjts1's Avatar
C320
I remember seeing around 175 peak in the 3.2 v6
Old Dec 7, 2019 | 05:34 PM
arcteryx's Avatar
W211 CDI
Accordingly to the diagnostics, the Boost pressure, Atmospheric pressure and Intake Air pressure should all be within 30 hPa. I measured mine, they are below
boost- 976
atmospheric -990
intake air- 790
I bought a new map pressure sensor and the same readings were thrown for both. I am thinking of replacing the MAF. I am throwing a e2025 B28/5 which is the signal voltage too high. I have noticed my MPG is significantly lower at 26-27 highway and it has a sluggishness.
It's possible the new Bosch sensor I purchased is bad, but I doubt that is the case. Is there any other sensor that would cause the intake to be lower? Can someone read their's and report back?
