E-Class (W211) 2003-2009
P0025 code, 2008 E350
Old Jan 6, 2020 | 07:03 PM
pizzano's Avatar
2008 E350
2008 E350
(CURRENT FAULT)
P0025-Powertrain
"B" Camshaft position- Timing over-retarded (Bank2), which sensor on the drivers side does this refer to , the magnetic adjuster or the position sensor, ( behind the oil cooler , or behind the power steering pump)
P0064- Powertrain
HO2S Heater Control Cricuit High (Bank 2 Sensor 3), I am to assume this code popped up due to the cam sensor code above
Thanks for any help, I know there must be numerous posts on this.
Old Jan 7, 2020 | 07:44 AM
konigstiger's Avatar
'71 Pinto
Old Jan 7, 2020 | 10:33 AM
pizzano's Avatar
2008 E350
Thank you!!!
Old Jan 8, 2020 | 09:04 PM
pizzano's Avatar
2008 E350
Replaced all 4 on drivers side Bank 2, code still pops up and check engine light is still on, does it take a driving cycle for the light to go off.
I cleared the codes using my BT adapter and Torque pro app which I use for my engine management for my autocross car, start vehicle up still runs normal but light still on and code keeps coming back.
I used all Mercedes parts also, any thoughts, I would drive it, but dont want to chance it wont start , even though it never acted like that to begin with.
Old Jan 8, 2020 | 10:24 PM
pizzano's Avatar
2008 E350
NM , light went off after driving it!!
