No bulbs, you can disassemble cluster to visually inspect (ribbon cables, etc.) however, more than likely you will need to replace cluster. Need VIN to provide compatible part #s to shop used, then swap board to retain mileage, etc.
hello Konigstiger,
do you have access to the actual schematic for the cluster? I have an intermittent cruise control segmented display problem, I am believing its a cold solder connection to a chip. It seems to be cabin temperature dependent. Shopping for a used cluster may have the same problem, it seems this is a common issue.
