E-Class (W211) 2003-2009
2007 e63 fuel pump pressure. Help!
Old Mar 26, 2020 | 04:51 PM
W211GANG's Avatar
E55/E63
My fuel pump is reading 4.3 max on the left for 4.2 max on the right. Is this normal for you guys?
Old Mar 28, 2020 | 07:03 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Each pump is controlled by its own fuel pump controller which are in turn are controlled by a PWM signal from the ECU. Pressure will vary from 4.0 to 5.5 Bar depending upon fuel demands of the engine as calculated by the ECU. Filter has a bypass valve that prevents more than 6 Bar of fuel pressure. Fuel pressure sensor is located on the driver's side front of fuel rail.
