E-Class (W211) 2003-2009
A/C Climate control problem
Old Jul 18, 2020 | 08:55 AM
J911brick's Avatar
W211 W204
2005 e320. Red light on A/C switch flashes three times when you press it but the A/C does not come on. Compressor was just replaced and system charged. The climate control does not have LED display so I cant figure out how to do a reset. Must this be done with a scanner or is there a way around that? Is it possible something else is wrong? Is there something else I should check?
Old Jul 18, 2020 | 10:10 AM
konigstiger's Avatar
'71 Pinto
See attached bulletin.
File Type: pdf
Old Jul 18, 2020 | 12:22 PM
J911brick's Avatar
W211 W204
Thanks for that bulletin. So I guess there is no way around it without diagnostics?
Old Jul 19, 2020 | 09:21 AM
Steve _KTM's Avatar
2007 Mercedes 320 Bluetec
I just changed my condenser because it was damaged when i hit a deer on the highway last week. I recharged the system and got the flashing lights so i took it to the dealer and in 10 minutes it was reset. Works great now but you need the STAR system.
