E-Class (W211) 2003-2009
Another OBD Scan Tool Query
Old Jul 21, 2020 | 03:35 PM
J911brick's Avatar
W211 W204
Too many options out there and parsing though it all is overwhelming. I need a tool that not only diagnosis all the systems on MB, but I also need one that can do at least basic coding and adaptations. SHould I just not waste my time go straight to Star? If so, who is a good seller and what should I be looking at when I buy? The one site I looked at had a ton of options.
Opinions and recommended models:
Swaben
Foxwell
Autel
Icarsoft
any others?
Old Jul 21, 2020 | 05:43 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Go straight to STAR and contact member PMercury.
Old Jul 21, 2020 | 06:31 PM
J911brick's Avatar
W211 W204
Thanks. I'll look into PMercury.
Old Jul 21, 2020 | 11:26 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I picked one up from Launch. It is an android tablet with an app on it that talks to a bluetooth dongle that plugs into the car/truck OBD port. So far I've used it on my Mercedes, Chevy, Jeep, Ford, and Toyota with great success. Yes, it will activate/deactivate/bleed the brakes on a Benz. It costs an extra few hundred bucks than a STAR system will, but so far it does all the same things AND it'll work on other brands.
Old Jul 21, 2020 | 11:47 PM
J911brick's Avatar
W211 W204
What model/version? Do you have a source?
Old Jul 22, 2020 | 12:45 AM
2013 ML350 Bluetec
I got the Launch X431V+ from Amazon; it was about $1100. Somehow I got a 10% discount thanks to viewing it on and off for a day or two before pulling the trigger on it.
Old Jul 22, 2020 | 04:36 PM
J911brick's Avatar
W211 W204
Anybody familiar with MBStartool(.com) out of the UK?
Old Jul 22, 2020 | 05:38 PM
kjb55's Avatar
I bought mine from there - good support, not so good software in my experience. Within a year I had found Peter and went with his software. Luckily my hardware is good. You will not regret going with Peter.
visit b e n z n i n j a d.o.t.c.o.m
Old Jul 22, 2020 | 07:20 PM
J911brick's Avatar
W211 W204
Its just the whole issue about finding and buying all the hardware. And then its not exactly cheap.Its easier to just buy a package that is ready to go.
Old Jul 22, 2020 | 07:22 PM
J911brick's Avatar
W211 W204
Do you know anything about the less expensive versions? Do you have to buy an annual license?
Old Jul 22, 2020 | 10:09 PM
2013 ML350 Bluetec
Mine came with 2 years of updates. After that, I can either renew the update program or keep the tool as is with no further updates.
Old Jul 23, 2020 | 08:55 PM
kjb55's Avatar
Peter advises what hardware to buy. Remotes in - does a complete install. You’re good to go.
Old Oct 22, 2025 | 01:20 PM
jimyj's Avatar
E320
I’ve been using the youcanic full-system scanner for a couple years on my Mercedes and it’s become my go-to because it’s easy to use, pulls codes from all the modules fast, handles most of the service stuff I need (adaptations, resets, bi-directional tests, DPF regen), and it works on other makes too with a nice topology view that helps trace issues; the flip side is it’s not a full Xentry replacement deep coding/programming and a few niche functions still need Xentry/Vediamo, and every now and then I’ll hit a task it can’t do. With that said I use it a lot on my older MB and family.
