Air suspension MAXED out!
2007 E550 2WD US MODEL
2007 E550 Left hand drive US model non 4matic
I have searched over and over and keep finding leak down to the ground diagnosis and such. Here is what I have going on Air malfunction light comes on for valve block. it shows a code C1350 on my Mac Tools scan tool. (Airmatic pressure release valve open circuit). I look cant find any wire issues that are obvious. Drive the car a little and the front suspension maxes out. It is as high as it can get. I park the car and it takes about 2 -3 weeks in the garage and the rear drops to the ground. The front is still all the way up. I order the valve block, figure as long as it is torn down that far the car has almost 140k miles on it. I should throw a compressor in there as well. So new valve block, compressor, and relay all get replaced. I personally thought when I pulled the lines off the valve block I figured that would let the air out of the front struts at least. I didn't replace the fuse as all fuses tested good with a test light. I found the underhood, the trunk and drivers fuse block it there another I am not aware of?
Is there some sort of system reset that I cant find on here for a W211? I don't want to do the coil over conversion I don't like the ride. I wanted one of these as a kid But I am losing interest quick after an expensive trans and some other parts that equal the cars current worth. If any of y'all can help me keep the enthusiasm I would appreciate it!
Is there a scan tool I can buy that is compatible to do more than jjust check engine lights without buying the Star and having to pay all of the subscription to Mercedes
2003 Mercedes E500(Sold), 2003 Mercedes CL55 AMG, 1980 Mercedes 450SL, 2005 Mercedes e320 CDI
I have a similar problem and was wondering if you had figured it out. My front suspension is all the way maxed out and no codes are being thrown(The code reader I use is a Icarsoft MB II). The back is sitting where it needs to be. I've tried a couple of thing and nothing seems to work. Any help would be nice, thanks.
Ill take a look at that, about 6 months ago I replaced my compressor so hopefully the compressor its self isn't the problem, Thanks for the help!
