Is it ok to replace the Air Filters myself?
Thanks.
Thanks.
Only tip I'll throw in is after changing the filter, make sure that air filter housing is sitting on top of the intake hole. Put your hand back there and feel where the air filter housing should be sitting on the air intake hole. Should not be any gaps. Sometimes getting the air filter housing to sit properly on the 4 rubber posts can be a picky. Putting a little silicon grease, or even just some water to wet the rubber posts will help the air filter housing to slide on correctly. Watch
The only things I outsource is jobs I don't want to do!
R
2MERKS
FWIW, I think doing it myself and being **** about ‘doing it right’ is one of the reasons my CDI has 230,000 miles and runs like new.
Peter
Just my humble opinion
R
2MERKS
That video is a good start. You'll need that torx bit. if you're a cheapo you can get a one off torx screwdriver.
The cover fits on the engine at five points...the intake at the rear, and four points at the corners of the box. there are a set of four metal claws on the box that fit tightly over four rubber ***** on the engine. check everything closely as these parts sometimes distort or break. you can live for a little while if one or two are not tip top, but you should get them replaced. After fitting the intake feel with your hand that the other points are fitting correctly. everything should snap into place when pushed down sharply. you'll be fine if you don't do anything dumb.
