E-Class (W211) 2003-2009
2005 E500 Will not start
Old Nov 21, 2020 | 03:50 PM
Linda Vigil's Avatar
E500 AWD
Unhappy 2005 E500 Will not start
My 2005 E500 was just fine until this morning. Got in, turned key fob and lights on console flashed, clock hands turned around a couple times, then nothing. Can not turn steering wheel, gear shifter will not move, fob will not open or close doors or trunk. Car has 94000 miles, has been maintained regularly and other than an issue with the seats not moving (which a mechanic fixed in about 5 minutes) its been a great car. So - is it time to invest a pot load of money in this vehicle? Please give me a place to start before I call a mechanic. Thanks in advance for any help.
Old Nov 21, 2020 | 04:41 PM
tjts1's Avatar
C320
Check fuses.
https://fuse-box.info/mercedes-benz/...uses-and-relay
Old Nov 21, 2020 | 05:12 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
Sounds to me like you have a battery on it's way out. Turn key to position 1, push reset button (left side of instrument cluster) 3 times to display battery voltage. Or. just try a jumpstart
Old Nov 22, 2020 | 12:58 PM
E500 AWD
E500 won’t start
Originally Posted by tjts1
Thank you for this info - I will be checking fuses right after I print some diagrams. Only one I have now is for the drivers side fuse box.
Old Nov 23, 2020 | 12:35 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Check your battery connections. Are they clean and tight?
