E-Class (W211) 2003-2009
Trunk Light Bulb replacement- Help
Old Aug 26, 2004 | 09:57 AM
jim256's Avatar
'03 Mercedes E320
I noticed the third trunk light (the one overhead, inside the lid, near the green flashing emergency release button) is not working now, the other two on the rear sides of the trunk are lit.
The fixture has a little give to pull it downward, but not enough to see what I'm doing. Has anyone removed the light fixture to replace the bulb, and how did the fixture release from the liner? (I can't find it in the manual.)Thanks in advance.
Old Apr 30, 2013 | 03:33 AM
jozh_93's Avatar
w212
Hi, I also have a problem with my trunk light and it needs to be changed.
Did you figure it out how to change it yet?
Old Apr 30, 2013 | 11:26 AM
konigstiger's Avatar
'71 Pinto
Check harness @ driver side trunk hinge if all is fine next step would be to remove trunk lid panel to access trunk lamp. If you need instruction sheet AR68.30-P-8150T PM your email address.
