E-Class (W211) 2003-2009
Can someone please put my mind at rest (or not)
Old Dec 30, 2020 | 10:48 AM
Allen James's Avatar
w211 e320 cdi 2005
So I just bought a W211 E320 CDI
2005.
when ever I unlock the car and open a door I get the following message appear in red.
Reduced braking power start engine.
I have replaced both batteries, and the brake light switch as a matter of course but it still appears.
is it a fault or is it normal ?
no fault codes using Delphi.
after 30 seconds ignition off it goes.
start engine it immediately goes.
Old Dec 30, 2020 | 11:34 AM
konigstiger's Avatar
'71 Pinto
Definitive diagnose have someone pull codes using MB diagnostics. Try brake switch as depicted in video (part # 0015454009) if this fails you do not list your location, MBUSA extended SBC warranty to 25 years have dealer check it.
Old Dec 30, 2020 | 11:38 AM
w211 e320 cdi 2005
I'm in the uk.
batteries and brake light switch were all genuine from dealers.
Old Dec 30, 2020 | 11:41 AM
'71 Pinto
You will need to have someone pull codes using MB diagnostics could be SBC hydraulic unit.
