E-Class (W211) 2003-2009
2002 E320 ESP visit workshop
Old Dec 30, 2020 | 02:52 PM
sawidzial's Avatar
2002 e320 base
Hello Mercedes forum, having issues with my 2002 E320 with ESP visit workshop popping up periodically while adding BAS light to it's display in the lower left hand corner. Car has 228,00 miles. When ESP light comes on after engine is warm, I lose blower motor and turn signals for about 1-2 minutes. Losing these features doesn't happen all the time. Those features come back and ESP light stays on. Sometimes restarting the vehicle removes this error. Installed a new battery and tried the left to right steering reset. Still have the problem.
I believe this is the correct thread. posted 210 and 213 previously
Old Dec 30, 2020 | 03:36 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
You'll likely get the same response in all sections: get codes read
I assume you really do want to be in the w210 section based on BAS. Your location on the planet would help determine your market
Old Dec 30, 2020 | 08:16 PM
wonderwilley's Avatar
86 BMW 635CSI
check the brake light switch behind the pedal or just replace it. I had the similar issue on both my 210s. That fixed it in both cases.
Old Dec 31, 2020 | 09:15 AM
sawidzial's Avatar
2002 e320 base
Got it. Stay tuned for results. Appreciate it Wonderwilly
Old Dec 31, 2020 | 02:44 PM
sawidzial's Avatar
2002 e320 base
Switch changed, still showing BAS ESP in lower left hand corner as well as intermediate blower and blinkers. Everything else working fine.
Mechanic suggested EIS causing this error message. Anyone ever here of this before? Very expensive fix.
Update. BAS ESP indicator only comes on after car runs about one hour. Every start after that is a crap shoot.
