Torque spec needed, oil separator
2006 E320 CDI. OM648.9. W211.026
could someone please look up the torque spec for oil separator (part #6460101462). There are (6) external torx, captive fasteners. It is what the oil cap twists onto.
Thank you
Hi konigstiger, the procedure pdf you attached is for either the 646 or 647 engine and not the 648 as you can see from my pic even though the doc lists the 648. That pdf shows only 2 fasteners on the oil separator. Although the torque spec for the 648 must be correct.
thank you
