Android head unit, HK tuner
Has anyone got the same setup that's successfully utilising the HK tuner or is this not a thing?
If that's your problem, you can look at the first post of this thread.... he goes through the factory GPS and antenna connection points and adapters needed. FWIW, I never could get the factory mic to work right with my Android unit, I gave up and ran the tiny little one that came with it to just below the instrument cluster. Radio reception on my Android unit is not nearly as good as factory. I just use Tune-In radio though and that resolves that issue.
https://mbworld.org/forums/e-class-w...-pics-txt.html
This is the one I used:
Bingfu Fakra Z Female to Male Vehicle Antenna Extension Cable 5m 16.5 feet for Car Stereo Android Head Unit GPS Navigation FM AM Radio Sirius XM Satellite Radio 4G LTE TEL Telematics Bluetooth Module
https://www.amazon.com/dp/B07HP647BX/ref=cm_sw_r_cp_api_glt_fabc_0X5A6GHNC70YFP1J29J1
