E-Class (W211) 2003-2009
Rear diff fluid change? What weight?
Old Jun 8, 2021 | 06:49 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow Rear diff fluid change? What weight?
While doing the transmission service I might as well do the rear diff of our 2009 e350 ( NON 4matic). I can't seem to find specifically what weight fluid is needed. When I check sites that have multiple things listed:
85W-90, or 75w-85
Which should we be using for the rear diff?
I found this:
A001 989 17 03 10: 85W-90
Or
A001 989 33 02 12 : 75w-85
Or
Part #001 989 3303 12 7: 75w-85
Just not entirely sure which one to get or which one our diff needs? I know it takes about 1.5liters. And do we know a part number for two new differential plugs (fill and drain)? I read that those should also be purchased new when replacing fluid, not to reuse the old ones.
Thanks,
-Nigel
Old Jun 8, 2021 | 08:13 AM
chassis's Avatar
2017 GLE350 4MATIC
See the Bevo site.
239.71 or 239.72, they are the same 75W-85 oil.
Buy the oil from a dealer. Front axle, rear axle and transmission.
Drain plugs can be found online at mbparts.mbusa.com or similar. Or if you have WIS/EPC from eBay, it’s $10-$20.
Old Dec 10, 2022 | 12:05 PM
gagan takker's Avatar
E 350
And https://www.liquimoly.com.au/1410-hy...-ls-sae-85w-90. ??
Old Dec 10, 2022 | 01:02 PM
Originally Posted by gagan takker
This is what I used when I changed mine several months back.
-Nigel
Old Dec 11, 2022 | 02:55 AM
E 350
I have a 2008 E350 (W211) in Australia
Mercedes sells at $ 100+ a litre as per current price and available on order
Alternative is LM 85W90 (Mineral) approx. $20 a litre
75w as I understand is the new synthetic one compared to older spec of 85W
