E-Class (W211) 2003-2009
VIN question
Old Jun 10, 2021 | 11:46 AM
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
VIN question
New to me 2006 E350 4Matic
90,000 miles
Would not have bought it unless it was in great shape!
What is it's color called?
Please help with the VIN decoding: WDBUF87J16X198129
I am interested in knowing everything that was included on this car when it was new.
Thank you
Old Jun 10, 2021 | 12:42 PM
konigstiger's Avatar
'71 Pinto
Cubanite Silver Metallic (code 723).
File Type: pdf
Old Jun 10, 2021 | 05:24 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
www.lastvin.com
Old Jun 10, 2021 | 05:50 PM
cetialpha5's Avatar
90,000 miles
Thank you
The 2006 model had the bad balance shaft. You didn't get outside of the range until the 2007 model year.
https://mbworld.org/forums/e-class-w...nce-shaft.html
Also had SBC brakes but that has an extended 25 year warranty from MB. You may also smell gas in the rear passenger cabin when filling up, MB replaces the gas tank if you smell gas. But that was only a 15 year extended warranty. That would have expired last year on you unless the in service date was after June 2006.
Intake manifold might also go, get a scanner than can do MB specific codes and see if there are any pending intake manifold codes.
Amazon Amazon
https://mbworld.org/forums/e-class-w...-manifold.html
Here's some general info on the car. You basically have a base model as you don't really have any options.
https://www.motortrend.com/cars/merc.../e-class/2006/
https://www.auto-brochures.com/mercedes_benz.html
