E-Class (W211) 2003-2009
New owner I hope
Old Jul 27, 2021 | 09:28 PM
kavadarci's Avatar
2012 C350 Edition 1
New owner I hope
I’m close to getting a 2007 w211 e550
its not my first Benz nor the oldest and I have two sets of questions for the experts:
1. car has 154.000km and was wondering what are the things I have to do first because I don’t have the car history.
spark plugs, transmission oil, differential oil coolant and brake flush, what else?
2. it’s too quiet for me. What gives the best sound?
x-pipe? Mufflers delete or upgrade to which kind?
very excited for this one
thank you for your time
Old Jul 28, 2021 | 09:02 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Fuel filter, engine air filter, cabin air filter, spark plug wires. Full inspection of the front suspension as by now bushings and/or ball joints will be beginning to fail. Inspect the coolant reservoir to see if it is beginning to turn brittle; just grab the edges between thumb and forefinger and see if it crumbles. If you replace the coolant reservoir also replace the hard line from the coolant reservoir to the upper radiator hose. It's not very expensive and it can get brittle with age.
Serpentine belt, idler pulley, and tensioner pulley.
Ensure you have the rubber covers that fit over the front sam, ecu, and brake fluid reservoir. The rubber covers are a belt and suspenders approach to ensure you do not get water into the ECU or front Sam in the event the plastic cover over the electronics is not securely fastened. That was an issue with the first couple of model years of the w211. Having personally experienced water intrusion into the ECU and front Sam, I can tell you that you do not want it to happen to your car.
Old Jul 28, 2021 | 09:38 AM
kavadarci's Avatar
2012 C350 Edition 1
thank you
i can do all that no issue.
how about transmission and front rear differential oil?
is there a maintenance manual online that I can look and figure out what is the manufacturer suggested maintenance?
Old Aug 2, 2021 | 08:11 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
Originally Posted by kavadarci
thank you
I just did the trans fluid and rear diff fluid about a month ago, maybe less. At that mileage you definitely want to do the fluid. My w211 only has 60k miles and the fluid was brown.... Not burnt but definitely needed replacing. I believe our transmissions require ever 40k miles to be done.
This is the one I used: All information you need to know and documentation is here:
DIY 722.9 7G-tronic 7-speed automatic transmission service thread - MBWorld.org Forums
Rear diff is super easy to do. Do yourself a favor and get some type of a hand pump. It took me 30 seconds to fill the rear diff with one. Before I would always struggle with trying to use tunes or funnels..etc.
-Nigel
Old Aug 2, 2021 | 08:54 AM
kavadarci's Avatar
2012 C350 Edition 1
How many litres of oil did you end up using?
thank you
