E-Class (W211) 2003-2009
Replacement iPod cable?
Old Jul 30, 2021 | 11:19 AM
wkalexand's Avatar
W211 E 350
2008 Mercedes e350 Sport
61,200 mi
Factory iPod kit - (iPod-Interface B6 782 42 52)
The 30pin iPod cable is frayed and non operative. I want to replace the cable (and attach a bluetooth adapter to the old iPhone (30pin) connector). Where do I find the replacement cable?
Old Aug 4, 2021 | 06:40 AM
wkalexand's Avatar
W211 E 350
bump
Old Aug 8, 2021 | 01:55 AM
dogsatemypants's Avatar
2008 E320 bluetec
I have the same problem, the 30 pin connector is hanging on by a thread, and causes a slight hum if i use aux cable. Barring a new cable, if i could get a diagram of the wires in the cable and what contacts they should be soldered to i would be pretty happy. My last and kinda out there thought would be hacking it off and somehow swapping with a usb plug.
Old Aug 10, 2021 | 06:05 AM
wkalexand's Avatar
W211 E 350
I ended up disabling the iPod adapter altogether by following this video tutorial:
Old Sep 6, 2021 | 11:40 PM
2008 E320 bluetec
Glad you got things working. The 3.5mm jack was enabled on mine so it worked, but had line interference. I think i might just get a bluetooth adaptor then. I wasn't sure what the other end of the cable looked like on the other end, or if it went into a separate module. Prolly gonna get one of these https://www.ebay.com/itm/39315762747...MAAOSwdPJgOI-N
Old Jan 4, 2022 | 02:36 PM
Broly's Avatar
2002 Acura TL-S and 2005 E320 4MATIC
B 67824531
(pictures aren't mine)
ymmv on availability, since mboemparts says it is discontinued.
apparently there is stock in toronna so i ordered one.
my existing cable has a white head, so i am kind of excited to see if this new one charges the ipod touch 4g and newer 30pin devices.
Last edited by Broly; Jan 4, 2022 at 02:37 PM. Reason: just stating picture isn't mine
Old Jan 5, 2022 | 06:36 PM
Broly's Avatar
forgot how aggravating it is to run this cable through the box, but it's done.
well worth it. no more static.
didn't test newer devices yet, but thrilled with how this turned out.
Old Jan 9, 2022 | 04:10 PM
Broly's Avatar
indeed it does charge the 4G touch, and thus i suspect all 30 pinners.
lol, the fraying on this old cable was when i pulled it through the hole instead of pushing it. still had some pinching from before (i could only get my hands on a used kit).
as you can see, the heat shrink approach did not help due to how much the cable moves and the location.
this thing is the bomb. there is no alternative once you have it (i have a dension gateway 500s as my CDC that i don't ever use, i got it for a great deal).
Old May 5, 2023 | 05:36 PM
Joalsato's Avatar
Mercedes CLK550 2009
Store for iPod Cable
Originally Posted by Broly
B 67824531
Hello, could you share the link to the place you got this cable from? For some reason it was previously cut when I got the car from a dealer.
Old May 5, 2023 | 10:58 PM
cetialpha5's Avatar
Good luck trying to find it. It's been discontinued and no one seems to have it anymore. Haven't seen one for sale in a couple of years. Mine was also falling apart. You could always just plug in the aux connector into Comand but then you won't be able to use an ipod.
Old May 5, 2024 | 07:46 PM
Großaspach's Avatar
S211.276
Has anyone replaced the OEM cable with a RJ11 to USB-C cable and tested with an Apple iPhone 15 or later?
Old Jun 24, 2024 | 03:40 PM
nke63svagon's Avatar
2018 E63s AMG 4MATIC+ Wagon, 2007 R63 AMG, 2007 SRT8 Jeep Grand Cherokee (sold), 1989 911 Carerra 4
Any luck?
