E-Class (W211) 2003-2009
Trunk button won’t close trunk
Old Sep 20, 2021 | 01:37 PM
Sadieceleste's Avatar
E350 4matic
Hello! The red button inside my trunk doesn’t work to close down the lid. When I press it, I hear the motor make the closing sound, but it just doesn’t go down. I have to push it down, then it makes the sound that it seals shut. The button on the trunk handle works to open the lid, but doesn’t go all the way up without me pushing it up. 2007 E 350 4matic. Please advise.
Old Sep 21, 2021 | 08:07 PM
cetialpha5's Avatar
It needs to detect the fob nearby. Did you change the fob batteries? Sometimes it also gets confused and then I hit the unlock button on the fob and then hit the red button again and then it works. Also you need to adjust the trunk handle back, if it's stuck in the open position that might also be the reason, you have to manually move it back.
Old Sep 21, 2021 | 08:34 PM
E350 4matic
the trunk handle doesn’t adjust. When I reach under there it’s a button. That works to unlock and open it when I have the key fob. No way to manually move anything.
Old Sep 21, 2021 | 11:34 PM
cetialpha5's Avatar
There's an exterior trunk handle that opens the trunk. When you have keyless go, you can just pull on the exterior handle outside the trunk and it will open the trunk when it detects the key. That handle tends to stick as the car ages so it might be stuck in the open position, you just have to move it back manually.
Old Sep 22, 2021 | 10:41 AM
E350 4matic
ive never seen an exterior trunk handle. I have an 07 E350 4matic. Where is it?
Old Sep 22, 2021 | 11:36 AM
cetialpha5's Avatar
It doesn't actually move that much. It's right above the license plate in the middle of the trunk. When you have keyless go, all you have to do is lift up the lever and it detects the key and unlocks automatically. Check your owner's manual.
Old Sep 4, 2023 | 10:56 AM
davidmudley's Avatar
E55 AMG
I have the same issue, did you ever get to the bottom of it? I even managed to record a short video of the movement that happens when you depress the "close trunk" button: https://youtube.com/shorts/pcbf1iH5zEU?
Old Sep 4, 2023 | 10:58 AM
rohitsharma01's Avatar
bmw
residential property in mumbai
residential property in mumbai is a city of stark contrasts, where soaring skyscrapers share the skyline with historic landmarks. The diversity of residential properties in this metropolis is astounding, offering options that cater to various lifestyles and preferences
Last edited by rohitsharma01; Sep 4, 2023 at 11:00 AM. Reason: residential property in mumbai
