E-Class (W211) 2003-2009
OBD2 Scanner
Old Sep 20, 2021 | 08:29 PM
baris41's Avatar
w211 e350 4MATIC
OBD2 Scanner
Hey guys,
I'm looking for a cheap obd2 scanner and i bumped to this. Would this work with my car? '07 e350 4Matic
Amazon Amazon
Old Sep 20, 2021 | 10:28 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
It would likely work but the "cheap" standard is the icarsoft mb2 for about 150. There's a newer version out for a few dollars more, and an old version for a bit less. It's a dedicated Mercedes scanner and can read pretty much every system on the car- and there are a lot.
Old Sep 21, 2021 | 08:05 PM
cetialpha5's Avatar
I would get the Thinkcar Pro. The ThinkOBD is a more basic scanner that just does OBDII codes, doesn't do MB specific system codes. Not too much more for the Pro. Launch is actually a big name, I've used their older code readers.
https://www.aliexpress.com/item/1005002419612264.html
Old Sep 21, 2021 | 08:54 PM
Gangrene3075's Avatar
03' Mercedes-Benz E500
I recommend the iCarsoft MBII Scanner.
Old Oct 11, 2021 | 06:19 PM
WIldcat465's Avatar
2007 CL600
I'm going to flush my ABC fluid. Can the iCarsoft MBII put the car in Rodeo mode?
Old Oct 11, 2021 | 07:33 PM
tjts1's Avatar
C320
This is what you want.
Amazon Amazon
Old Oct 11, 2021 | 08:30 PM
WIldcat465's Avatar
2007 CL600
Originally Posted by tjts1
Cool...thanks. Flushing the system looks much too easy to have it done by the dealer.
