Are doors between 07 E350 and 08 E300 interchangeable?
I am looking to replace the left side front door on my 2008 E300 4-door sedan and have been searching for a spare. I found a parts donor nearby but it is a 07 E350 4-door sedan. Will the subject donor door fit my car?
Thank you so much for your response, Konigstiger. I may be a little thick as I didn't know how to interpret it. Are you saying that all doors are compatible for W211 models between 2003 and 2009?
Key in 2117201305 here: https://www.mercedespartscenter.com/ see fitment.
Following up: found a left front door from a 2003 E320 at a scrap dealer, instead of a 2007 E350 which I originally intended. There's a caveat people need to be aware of. My 2008 MB is a facelift model, and the door I used is a pre-facelift door. The mirror mount on a pre-facelift door in incompatible with a facelift mirror assembly. My body shop needed to cut, form and weld a new piece of metal to adapt the pre-facelift mount to the mirror assembly. If the door I had obtained was from 2007 onwards, I would not have had this problem.
