E-Class (W211) 2003-2009
Code: P0171, P0170 and P0140. E200 kompressor
Old Nov 5, 2021 | 02:42 AM
Icelandicbenz19's Avatar
E430
2004 E200 kompressor, w211.
On my way home check engine light came on, car drives normally and idles normally both hot and cold. since the scanner is generic i'm not sure on how to tell what those codes are.
Old Nov 5, 2021 | 05:50 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
https://mbworld.org/forums/e-class-w...0171-code.html
Old Nov 5, 2021 | 06:09 AM
E430
Mine drives, idles and accelerates fine. All these codes came at same time, no codes where stored before
Old Nov 5, 2021 | 09:22 AM
JCM_MB's Avatar
You can start by deleting the codes, and wait to see if they are temporary. Check them again after a drive and not wait for the CEL to come up. The first code to trigger is the first sign, the next one is sometimes a consequence of the previous one
Old Nov 5, 2021 | 09:29 AM
E430
I deleted yesterday and they came up this morning while driving to work again
Old Nov 5, 2021 | 10:02 AM
JCM_MB's Avatar
Check codes again, that is the car asking for help
Old Nov 5, 2021 | 10:12 AM
E430
Same codes
Old Nov 5, 2021 | 10:13 AM
E430
Same codes
Is it possible P0140 the o2 sensor is causing the other 2 codes?
Old Nov 5, 2021 | 10:15 AM
JCM_MB's Avatar
Did you read the thread, or just the first message?
Start with the suggestion for MAF, then O 2 sensor. Diagnosis/triage and analyze the data
Old Nov 5, 2021 | 10:45 AM
E430
I read it. ill get an live data😎
Old Nov 5, 2021 | 01:32 PM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
https://www.mercedesmedic.com/merced...s-p0170-p0173/
