E-Class (W211) 2003-2009
Metal intermittent grinding sound when turning
Old Nov 9, 2021 | 04:50 AM
stianlundell's Avatar
W211 E280 4Matic
W211 4Matic
I am having some serious metal grinding sound when turning. The sound is intermittent, and often occurs when turning almost all the way to the right. I think the sound is coming from the front right side. It`s almost like rotors crushing into rotors. The car also makes grinding sound when turning in low speed, but not as much as the intermittent sound.
I have replaced both CV axles (OEM parts), engine and transmission mounts, tie rods, TC oil, and checked oil-level of front differential. In higher speeds the sound dissapeares.
Anyone got a clue what this can be? Thanks.
Old Nov 9, 2021 | 08:37 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Originally Posted by stianlundell
W211 4Matic
If it were my car, I would lift it and
  1. check brake disc both sides and the pads,
  2. rotate the wheel while putting lateral pressure -- > listen to the bearing noise
  3. I would try to check the front axle somehow regardless if they are new (you never know)
  4. and since your car is 4matic, correct? --> Check the front drive axle for the U-Joint, they seem to disintegrate
I do not recall which another rotating part is located on the right side that may relate to the turning
Old Nov 12, 2021 | 06:06 AM
W211 E280 4Matic
Thank you!
Took my car to a lift yesterday and checked some of the points you mentioned. When Im rotating the wheel i`m getting some kind of chattering, which increases with the speed. Found a video on youtube with excact same sound, where he found out it came from the wheel bearing.
. Will try to replace it soon, and then return with a update.
Old Nov 12, 2021 | 06:48 AM
hangit06's Avatar
2006 E320 CDI
I had the same sound, wheel bearing.
