E-Class (W211) 2003-2009
Easy Entry/Exit not working as intended
Old Nov 13, 2021 | 02:44 PM
Jodul's Avatar
None (Yet)
Title explains it all really. At random earlier today, the easy entry/exit function stopped working fully. It works partially. Putting the key in, the column adjusts to the chosen position, and if the seat is back, the seat goes to the position it's set to. However, open exiting, the column goes back up, the seat doesn't. Manually moving it back using the controls works fine, and like above, it goes forward to the set position when you get back in and put the key back in the ignition.
Is there a way to reset easy entry/exit or fix the issue? We can't think of anything that would have caused it. We parked up, got out, bought things from the shop and it stopped working correctly when we got back.
Old Nov 17, 2021 | 02:44 AM
mseigno's Avatar
CL 500 (W216) 2012 & E500 (w211) 2002
Hi,
This thread will definitely help you to fix the issue…:
https://mbworld.org/forums/c32-amg-c...t-working.html
Old Nov 20, 2021 | 05:52 PM
Jodul's Avatar
None (Yet)
Originally Posted by mseigno
Hi,
Didn't help - Followed instructions exactly as read. The memory function stopped working on ours. It won't save any position. It'll only call back previously stored ones.
Old Nov 21, 2021 | 10:04 AM
konigstiger's Avatar
'71 Pinto
Model, model year, location or VIN?
Old Nov 21, 2021 | 02:38 PM
Jodul's Avatar
None (Yet)
E55 AMG - Early 2004. UK. If you need the VIN, I'll go outside and copy it if needed.
Old Nov 22, 2021 | 09:25 AM
'71 Pinto
Check hall sensor, attached bulletin will assist.
File Type: pdf
Old Nov 27, 2021 | 03:07 PM
Jodul's Avatar
None (Yet)
Didn't help - Hall Sensors were still connected correctly. Memory Function has returned, though. Still won't adjust the seat for Easy Entry/Exit
