E-Class (W211) 2003-2009
AC not blowing
Old Nov 15, 2021 | 02:21 PM
KarenM's Avatar
2004 Mercedes e320 wagon
AC not blowing
I have a 2004 MB E320 wagon. It started with my AC blowing intermittently. It would blow for a bit and then stop, then start and stop, etc. it would also sometimes continue to blow for a few minutes after turning the car off. Now, it won’t blow at all, but I can hear the compressor coming on. So I feel like it has something to do with the fan. I checked the fuses and they are good. Please help!
Old Nov 16, 2021 | 09:00 AM
konigstiger's Avatar
'71 Pinto
Most common cause, malfunctioning fan regulator part # 2308216451. Given age of vehicle also inspect condition of blower 2118300908.
File Type: pdf
Old Nov 17, 2021 | 01:02 PM
KarenM's Avatar
thank you!!!
Old Nov 17, 2021 | 04:38 PM
KarenM's Avatar
If I can only afford to replace one of these at a time, which would you recommend doing first?
Old Nov 17, 2021 | 05:18 PM
'71 Pinto
Your call upon visual inspection: https://www.pelicanparts.com/techart...or_Testing.htm
Search either part #: https://www.fcpeuro.com/Mercedes~Benz-parts/
Old Feb 12, 2022 | 01:30 AM
yelreppa's Avatar
W210 E230 1997
Hi Konigstiger,
I have a w211 2007 E200K in Aust with a noisy blower fan. Could be a bearing or rubbish inside the fan. I am thinking to replace it with a W211 E63 AMG AC Heater Blower Motor Fan J146 - Can you tell if this fan assy would fit and run in my W211 2007 E200K RHD ? It looks and seems to be same but the seller cannot find any MB part number on the fan.
Cheerz Stuart from Australia
Old Feb 12, 2022 | 04:05 PM
'71 Pinto
Suggest shopping #s here:
Old Feb 13, 2022 | 12:07 AM
yelreppa's Avatar
W210 E230 1997
Thank you for the expanded parts diagrams.
My question to you was - Will the mercedes benz e63 amg w211 2007 ac heater blower motor fan j146 fit into my w211 2007 E200K and work with out any issues. Or is it a different part the the fan currently in in W211 E200K 2007 sedan ?
I am looking at the E63 W211 Fan on an ebay site in Australia. Hope you understand what I am asking. Ijust dont want to buy this item and find it is not suitable.
Thanks in advance. Stuart
Old Feb 13, 2022 | 09:17 AM
'71 Pinto
And my answer to you is since this is not an MB part # pass and shop MB part #s 2119062400 new/used, 2118301008 and 2118300508 used.
