s211 tailgate switch door panel
I´ve retrofitted the automatic tailgate, but I´m struggeling finding info on how to wire the driver door panel switch. I was surprised to find that the tailgate button wires are inserted into the existing harness. Is it the same for the front switch? Or is there a dedicated connector on the door panel control unit?
If so can someone tell me the part number? The switch has a 4 wire connector, so those 4 wires need to go somewhere
When I did the tailgate retro fit everything was 100% plug and play. Then I just coded the car and everything works. Very easy mod to do minus taking the back seat deck lid out.
-Nigel
I also have a retrofitted hydraulic tailgate on my S211. The set came without the switch for the driver's door. And although it works (just using the handle and button on the tailgate itself to open c.q. close), it would be nice to add the button in the driver's door as well. They are not that expensive, and AFAIK are easy to plug in to the door control module.
However, all info I can find is about swapping an existing button -- my car doesn't have a button there in the first place. I'm wondering how to physically install the button in the door/speaker cover. I didn't pull off the cover yet; hoping to find some info before I start the job (and then do it in one go).
The cover in my car seems (from the outside) to be blind. On videos about the swapping of buttons, I see that there is not just a hole but a mounting bracket on the inside of the panel. Can the hole be "pushed out" with the cover removed and is the switch bracket always there? Or is the speaker/door cover with the switch mounting (and the hole) a separate part? If so, does someone have a part number?
