E-Class (W211) 2003-2009
E320 V6 Oil Sensor Leak
Old Dec 2, 2021 | 11:31 PM
Cambz's Avatar
S55
2005 E320 gas V6, have what looks like a oil leak from the oil level/temp sensor.
There is a TSB this # P-18-40-29A from 7/2006 but all linked info posted here is not working so I can't get any details.
FCP Euro has the replacement sensor and Pelican has change out instructions BUT I can't find or see any details on how the sensor seals to the pan.
My sensor works fine and I'd just like to fix the leak but I can't find any info on how it seals to the oil pan.
Does it use an O-ring, a gasket, or the same goop in a tube that the oil pan uses to seal to the block with?
Old Dec 3, 2021 | 08:46 AM
konigstiger's Avatar
'71 Pinto
Sealing ring part # 0249977048.
File Type: pdf
Old Dec 3, 2021 | 12:25 PM
Cambz's Avatar
S55
Awesome, thanks for the directions ,that part number is exactly what I needed.
Old Dec 4, 2021 | 09:46 AM
F1Fan's Avatar
Just be aware that it may be the actual sensor that is leaking. The sensor can crack and develop a small leak, even though the sensor is working normally. I had a leak down there and replaced just the o-ring sealing the sensor to the oil pan. Filled the car back up with oil and still had a soaked oil sensor at my next oil change. Replaced the sensor with a new one and now there are no more leaks around the oil level sensor. If you do change the o-ring, I would suggest you take a very close look at your oil level sensor.
