E-Class (W211) 2003-2009
Should my mirror dip to park?
Old Sep 23, 2004 | 02:31 PM
latent's Avatar
When I select reverse, should my passnger mirror dip to aid reversing (cos it doesn't!)
Model: 2005 E320CDI
Old Sep 23, 2004 | 02:36 PM
BklynBenz's Avatar
CL500
it should and its supposed to go down. with my clk, if the passenger side mirror button isnt pressed down then the mirror wont go down when the car is in reverse.
Old Sep 23, 2004 | 02:42 PM
Barry45RPM's Avatar
2015 ML 350
For it to do so, you must first...
1. Put the mirror in its downward (parking) position
2. Press M and then the down arrow of the mirror adjustment buttons.
3. Always leave the mirror adjust button for the curb side mirror pressed in.
4. Memorize the seat positions again for driver that you are. (or all 3)
As long as the same memorized driver/key uses the car & all of the above are done. it will work.
Old Sep 23, 2004 | 02:43 PM
outtadaloop's Avatar
2004 W211 - 2004 MV Agusta SPR
check your manual for parallel parking assist or something like that. it should give you the exact directions on how to set that feature.
Old Sep 23, 2004 | 06:13 PM
paulhu's Avatar
Whichever one is available (1 of 5)
You must do the settings from the steering wheel menus. There is an option to set the passenger side mirror to dip when you shift in reverse. It's in the manual somewhere.
Old Sep 23, 2004 | 06:55 PM
moa4r's Avatar
S4
you have to keep the button for adjusting the mirror in the passenger side position (as if you are going to adjust the passenger mirror) this should cause it to lower when you put it in R
Old Sep 23, 2004 | 07:02 PM
BklynBenz's Avatar
CL500
thats what i said. if that buton is not in, then it doesnt work. its as simple as that
Old Sep 24, 2004 | 04:02 AM
latent's Avatar
Hmm. I do not have memory seats! It does not show up as an option in vehicle covenience either.
BUT, I assumed that reverse park aid was not dependent upon having memory seat package - IMO it shouldn't be!
Old Sep 24, 2004 | 05:41 AM
andyKen's Avatar
E320 CDI
This feature IS only availalbe with the drivers memory seat package (at least on UK vehicles). Even then it is not easy to find out how to set it.
Old Sep 24, 2004 | 03:50 PM
my E430 rocket's Avatar
BMW X3. R33 skyline
i thought they all would come with memory?
Old Sep 24, 2004 | 05:18 PM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
Sorry,
Different countries, different specs. You have cup holders, we have electric folding mirrors. (cup holders are only an option) Go figure????
Regards,
John
Night time in Torquay
