E-Class (W211) 2003-2009
Power steering pressure line replacement
Old Jan 7, 2022 | 03:06 PM
bkozhuharov's Avatar
2005 Mercedes-Benz E320
Hey guys,
Happy new year! I found a pretty bad leak in the power steering pressure line. Not really noticeable while the wheel is straight, but when turned all the way to either side, it literally starts squirting fluid from couple of tiny holes on the hose. I did some DIY video search to replace the whole pressure line, and it doesnt seem like too too hard job to do myself, or at least looks that way. My question, assuming that this is the only leak, would just disconnecting the old one, connecting the new one and refueling the power steering fluid be enough, or is there more to it - flushing the system etc.
The car in question is 2005 E320 Base Sedan.
Attached are some pictures from the car (the white chalk is where the leak is)
There is a link to the part that I believe I need (please correct me if wrong) - https://www.partsgeek.com/catalog/20..._hose_assembly
And there is a link to the video that I plan to follow -
Thanks a lot !!
Old Jan 7, 2022 | 03:54 PM
konigstiger's Avatar
'71 Pinto
See attachments.
Old Jan 7, 2022 | 05:52 PM
See attachments.
Thank you so much! Does the part from the link I shared look ok?
Old Jan 8, 2022 | 09:52 AM
'71 Pinto
Cross reference MB part # when shopping. Attachment covers all associated parts (i.e.: seals, etc.).
File Type: pdf
Old Jan 10, 2022 | 02:12 PM
You are all awesome! Thank you so much!
