E-Class (W211) 2003-2009
Cant get rear hub seated on LCA - Need advice
Old 01-09-2022, 07:17 PM
ISSWorld2's Avatar
2011 E550
PO swapped my w211 e320 wagon over to rear coils, but he used the sedan coils and the rear end sags. So, I decided to install proper wagon rear coils.
Here's where I am stuck. I cant get the lower control arm to seat back in its place on the hub I haven't found a way to leverage it back in place. Striking the wheel mating surface of the rotor does nothing to re-seat the LCA.
(see attached pic and the 9:50 mark of this youtube video -
At the 9:56 mark of the video, the LAC and hub are magically back together.
Pic is a screen grab from the video, not my car.
I have until the 14th to fix the car, because my son needs it to go back to college out of state.
Old 01-09-2022, 09:34 PM
tjts1's Avatar
C320
Have you tried a hydraulic floor jack to push the control arm up?
Old 01-09-2022, 10:37 PM
ISSWorld2's Avatar
2011 E550
Yes.
I think I am going to sand down the metal bushing in the LCA until I can get it back in place. Several YT commenters mentioned how difficult this was. One resorted to sanding.
Old 01-10-2022, 12:58 AM
tjts1's Avatar
C320
Originally Posted by ISSWorld2
Yes.
before sanding, use a caliper gauge to measure the length of the bushing vs the space in the control arm.
Old 01-10-2022, 08:14 AM
ISSWorld2's Avatar
2011 E550
Roger that.
Old 01-10-2022, 11:37 AM
amosfella's Avatar
2004 E500 wagon
Have you tried undoing the top arms, attaching the lower arm, and then reattaching the top arms?
Old 01-10-2022, 06:35 PM
ISSWorld2's Avatar
2011 E550
I sanded off .5mm or so and it went right back together. Thanks all.
Quick Reply: Cant get rear hub seated on LCA - Need advice
