airmatic issues. short pump op and rear spring clicks
Im having issues with my airmatic system 2003 E500. The car will not raise up. mostly in the rear. but front is also lower than before.
I replaced the valve block and compressor. Still not raising to proper levels.
I replace the compressor but what i notice is the compressor comes on then shut down rather shortly.
Also I hear clicking on the rear air spring which are Arnott replacements. sounds like some type of electric relay or valve sound.
displays shows airmatic visit workshop.
I did not replace the compressor air filter will that come in play with the issues?
Thanks.
Thanks.
You should also ensure the rear level sensor did not become bent or damaged.
Good luck with diagnosis.
