E-Class (W211) 2003-2009
Front brake discs
Old Jan 18, 2022 | 10:20 PM
jave808's Avatar
2007 W211 E280
Front brake discs
Hi
Just had my car serviced. All fluids and filters.
The mechanic did tell me that I'll be due for new brake pads and rotors soon.
I've looked up on DBAs website (supplier here in Australia). See https://dba.com.au/products/catalogue/dba-part-finder/
and there are 3 different sizes for the front rotors. How do I tell which ones to buy? My E280 is a base model - no AMG or Sports. So I'm guessing the 295mm diameter ones.
Old Jan 19, 2022 | 09:20 AM
konigstiger's Avatar
'71 Pinto
Post VIN I will pull MB part # to cross reference.
Old Jan 19, 2022 | 03:51 PM
jave808's Avatar
2007 W211 E280
Many thanks
VIN: WDB2110542B198601
Old Jan 19, 2022 | 03:57 PM
'71 Pinto
File Type: pdf
Old Jan 19, 2022 | 04:12 PM
jave808's Avatar
2007 W211 E280
Thank you!!
One thing I did notice. The front rotor is 295mm in diameter and the rear rotor is 300mm in diameter. Is this normal?
And do I also need to replace the wear sensors?
Old Jan 19, 2022 | 04:22 PM
'71 Pinto
Yes. Wear sensors determine replacement upon inspection.Although e280 is not listed check here for compatible aftermarket entering MB part #s given: https://www.fcpeuro.com/Mercedes~Benz-parts/
Old Jan 19, 2022 | 06:34 PM
cetialpha5's Avatar
I thought you only needed to replace them if the light telling you to replace the brake pads was on. As it was just the mechanic that told him to replace the brake pads, it sounds like the light isn't on yet. I believe what happens is that when they wear away, the contacts are broken and you get a light. If the contacts aren't worn away, you should be able to reuse them, but depending on how bad they are, they may be slightly worn away already, but not enough to break the contact.
Most of the time when you buy front brake pads like Akebono, they come with the sensors but others might not come with them.
Old Jan 19, 2022 | 09:27 PM
jave808's Avatar
2007 W211 E280
Thanks. No warning lights - yet! Mechanic did a visual inspection on the pads.
So I've ordered new pads and rotors - front and rear. I feel I will get away with the old wear sensors, but time will tell.
If I did get new sensors, are they the same sensors for left and right? So front left and right the same, and rear left and right the same?
Old Jan 20, 2022 | 08:53 AM
'71 Pinto
Visual inspection of connector/harness should always be done when replacing pads.
Yes was in response to:
Old Jan 20, 2022 | 09:14 AM
robbieas's Avatar
'07 E350 (W211)
Thank you!!
Those sensors are like $3 and they aren't on all 4 wheels.... I'm almost positive it was just 2 (1 F and 1 R). I'd just order them.
Old Jan 20, 2022 | 09:08 PM
jave808's Avatar
2007 W211 E280
Thanks. Will do. No warnings yet but will replace pads and discs when it arrives.
Old Jan 26, 2022 | 08:05 PM
Sverker's Avatar
E320 CDI W211 Wagon
@konigstiger Can you crosscheck my vin also for the same topic? WDB2112221B371857
Old Jan 27, 2022 | 09:16 AM
'71 Pinto
File Type: pdf
Old Jan 27, 2022 | 10:02 AM
Sverker's Avatar
E320 CDI W211 Wagon
@konigstiger Thank you very much, that means I should have the biggest variant with 330 mm diameter.
Old Feb 14, 2022 | 05:48 PM
rs732's Avatar
2008 e350
@konigstiger Could you provide me with the brake info for my car as well? WDBUF56X78B190654
I need to order parts and not certain what parts and sizes the car needs.
Best regards,
Old Feb 15, 2022 | 09:11 AM
'71 Pinto
If considering MB parts start here to comparison shop: https://www.mbwholesaleparts.com/starparts - view PDF list.
File Type: pdf
Old Feb 15, 2022 | 03:46 PM
rs732's Avatar
2008 e350
@konigstiger thanks! I looked up the parts but it appears some are unavailable. Would a kit like this be compatible with my model? Thank you for your help!
https://www.ebay.com/itm/Front-and-R...-127632-2357-0
Old Feb 15, 2022 | 04:16 PM
'71 Pinto
Yes. according to the vendor's link you provided.
Your MB front disc is 295mm:
Old Feb 16, 2022 | 05:52 AM
ilium007's Avatar
2003 E240
Hi @konigstiger could I pls trouble you to check my VIN for brake parts (front and rear)?
VIN: WDB2110612A252738
Old Feb 16, 2022 | 11:14 AM
'71 Pinto
Old Feb 16, 2022 | 12:14 PM
rs732's Avatar
2008 e350
Thanks again for your help. I ordered the kit and will get them installed sooner than later. Best regards.
Old Feb 17, 2022 | 01:12 AM
ilium007's Avatar
2003 E240
Thanks @konigstiger
Old Aug 17, 2024 | 02:36 AM
jalluta's Avatar
W211 E350
W211 E350 322mm disc swap to 330mm
Hi!
I have a W211 E350 Sport with 322mm front discs. All the local dealers have only 330mm discs available. Would that with there?
VIN: WDB2110561B049228
Thanks!
Old Aug 17, 2024 | 12:36 PM
tjts1's Avatar
C320
"would that with there"? 🤔
Old Aug 17, 2024 | 01:31 PM
jalluta's Avatar
W211 E350
Would the 330mm disc fit there or is it too large?
W212 seems to have 322mm discs but not W211🤨
