2006 W211 3.5L Right Side Cams
107,XXX miles
Getting repeated P0015 fault.
CODE DISPLAYS AS: "Continuous Camshaft Adjustment (right) Incorrect Position of Exhaust Camshaft
ACTIONS/OBSERVATIONS: Set crankshaft at 305 deg and circle stamping appear to be centered on both cams.
Replaced all (4) position sensors, 2 right side, 2 left side.
RESULTS: P0015 fault code returned
The magnetic sensors are original. I thought I would pull the right side upper (exhaust) and clean it.
Anyone with experience just cleaning?
Is the right bank exhaust cam the upper?
TIA!!
